Introducción
This guide will instruct a user on how to remove the battery in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
Qué necesitas
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
3 personas más completaron esta guía.
2 comentarios
Only four 6mm screws retaining battery, middle screw secures by passing through back cover. Otherwise very helpful.
i followed every step on this guide and when i was finished my laptop wouldn’t turn on
