Saltar al contenido principal
HP Pavilion 11 x360 Speakers Replacement
Qué necesitas
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: paso 1, imagen 1 de 2 HP Pavilion 11 x360 Speakers Replacement, Remove Screws: paso 1, imagen 2 de 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: paso 2, imagen 1 de 3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: paso 2, imagen 2 de 3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: paso 2, imagen 3 de 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: paso 3, imagen 1 de 2 HP Pavilion 11 x360 Speakers Replacement, Detach Cable: paso 3, imagen 2 de 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: paso 5, imagen 1 de 3 HP Pavilion 11 x360 Speakers Replacement: paso 5, imagen 2 de 3 HP Pavilion 11 x360 Speakers Replacement: paso 5, imagen 3 de 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: paso 6, imagen 1 de 2 HP Pavilion 11 x360 Speakers Replacement: paso 6, imagen 2 de 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: paso 7, imagen 1 de 2 HP Pavilion 11 x360 Speakers Replacement: paso 7, imagen 2 de 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: paso 8, imagen 1 de 3 HP Pavilion 11 x360 Speakers Replacement, Speakers: paso 8, imagen 2 de 3 HP Pavilion 11 x360 Speakers Replacement, Speakers: paso 8, imagen 3 de 3
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: paso 9, imagen 1 de 3 HP Pavilion 11 x360 Speakers Replacement: paso 9, imagen 2 de 3 HP Pavilion 11 x360 Speakers Replacement: paso 9, imagen 3 de 3
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
Conclusión
2 personas más completaron esta guía.
Natalie
Miembro Desde 01/22/15
937 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-9, Maness Winter 2015 Miembro de Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 19
Todo El Tiempo: 1,721
