Saltar al contenido principal
HP Pavilion 11 x360 Battery Replacement
Qué necesitas
  1. HP Pavilion 11 x360 Battery Replacement, Remove Screws: paso 1, imagen 1 de 2 HP Pavilion 11 x360 Battery Replacement, Remove Screws: paso 1, imagen 2 de 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Battery Replacement, Remove Backing: paso 2, imagen 1 de 3 HP Pavilion 11 x360 Battery Replacement, Remove Backing: paso 2, imagen 2 de 3 HP Pavilion 11 x360 Battery Replacement, Remove Backing: paso 2, imagen 3 de 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Battery Replacement, Detach Cable: paso 3, imagen 1 de 2 HP Pavilion 11 x360 Battery Replacement, Detach Cable: paso 3, imagen 2 de 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Battery Replacement: paso 5, imagen 1 de 3 HP Pavilion 11 x360 Battery Replacement: paso 5, imagen 2 de 3 HP Pavilion 11 x360 Battery Replacement: paso 5, imagen 3 de 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Battery Replacement: paso 6, imagen 1 de 2 HP Pavilion 11 x360 Battery Replacement: paso 6, imagen 2 de 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Battery Replacement: paso 7, imagen 1 de 2 HP Pavilion 11 x360 Battery Replacement: paso 7, imagen 2 de 2
    • Remove the battery.
Conclusión
27 personas más completaron esta guía.
Natalie
Miembro Desde 01/22/15
937 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-9, Maness Winter 2015 Miembro de Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Miembros
12 Guías creadas
11 comentarios
exellent and easy steps............but......where do i buy battery.....?
Akshay R Manohar - Contestar
Muy bueno parece facil
mejiawilson - Contestar
Great step by step explanation. Solid pictures!!! Could not have fixed this without your contribution!!!
Joe Consumidor - Contestar
Purchased this laptop 28/12/2015 and now its just not switching on at all. I will try the repair instructions but I think it should have lasted a bit longer, what ever the problem is. The store where I bought it have checked the cable for me to see if that was the problem and it wasn’t. They wanted £60 to send it off, to find out the issue before anything was even done. The sales assistant said it could be the battery but he said it should have lasted longer. He basically said if its the motherboard you may as well just throw it out. I am sick of paying £100’s out for electrical items that live very short lives. My daughter bought this with her own money that she had been saving. I would not purchase this make of laptop again and where do I get a replacement battery and how much is that likely to be?
jane coombes - Contestar
Very good guide, thank you!
FanMac - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 57
Todo El Tiempo: 59,794
