Introducción
A damaged scanner glass will at best produce poor quality images, and at worst damage other parts of the printer or cause injury. Replacing the scanner glass only requires a couple tools and a little patience.
Qué necesitas
Grasp the scanner lid cover from the front of the device and lift lid all the way up until it stands on its own.
Locate the finger notch on the inside top left half of the bezel (control) panel cover.
Place your index finger in the notch and lift up to unsnap the panel.
Set the panel cover aside.
From the back of the printer, locate the two large plastic tabs as shown.
With your index fingers underneath each tab, gently and simultaneously pull the tabs towards you and upwards to release the tabs from the plastic clasps behind them.
Remove the whole plastic frame that holds the glass.
Una persona más ha completado esta guía.
