Saltar al contenido principal
HP Omni 10 Battery Replacement
Qué necesitas
  1. HP Omni 10 Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10 Battery  Replacement: paso 2, imagen 1 de 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10 Battery  Replacement: paso 3, imagen 1 de 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10 Battery  Replacement: paso 4, imagen 1 de 2 HP Omni 10 Battery  Replacement: paso 4, imagen 2 de 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10 Battery  Replacement: paso 5, imagen 1 de 2 HP Omni 10 Battery  Replacement: paso 5, imagen 2 de 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
Conclusión
3 personas más completaron esta guía.
Alex Miller
Miembro Desde 10/11/16
345 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Fall 2016 Miembro de USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 3,963
