Saltar al contenido principal
HP Omni 10 Speaker Replacement
Qué necesitas
  1. HP Omni 10  Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover from the tablet.
    • The cover is securely fastened to the device and may be difficult to remove.
  2. HP Omni 10  Speaker Replacement: paso 2, imagen 1 de 1
    • Push the black plastic security flaps into an upward position.
    • Lift the small tab on the security strips up and peel them across the battery. They will be attached via adhesive.
    • Lift the tab on the strip up and pull it across the battery.
    • The orange strip does not fully detach from the tablet like the other three. It will only detach from one side.
  3. HP Omni 10  Speaker Replacement: paso 3, imagen 1 de 1
    • Unscrew the ten 3.3 mm screws securing the battery using a 00 Phillip's head screwdriver.
  4. HP Omni 10  Speaker Replacement: paso 4, imagen 1 de 2 HP Omni 10  Speaker Replacement: paso 4, imagen 2 de 2
    • Unhook the cord from the edge of the battery.
    • Pull the wire circuit out and down.
  5. HP Omni 10  Speaker Replacement: paso 5, imagen 1 de 2 HP Omni 10  Speaker Replacement: paso 5, imagen 2 de 2
    • Lift the battery up by its edges and remove it carefully. There will be adhesive holding the battery down.
  6. HP Omni 10  Speaker Replacement, Micro Card Reader: paso 6, imagen 1 de 1
    • Unscrew the two 3.3 mm screws using a 00 Phillip's head screwdriver.
  7. HP Omni 10  Speaker Replacement: paso 7, imagen 1 de 1
    • Lift and remove micro card reader board.
  8. HP Omni 10  Speaker Replacement, Speaker: paso 8, imagen 1 de 1
    • Unscrew the four 3.3 mm screws using a 00 Phillip's head screwdriver.
  9. HP Omni 10  Speaker Replacement: paso 9, imagen 1 de 2 HP Omni 10  Speaker Replacement: paso 9, imagen 2 de 2
    • Pull the black and white wire connector up to disconnect it.
  10. HP Omni 10  Speaker Replacement: paso 10, imagen 1 de 2 HP Omni 10  Speaker Replacement: paso 10, imagen 2 de 2
    • Pull the red and black wire connector up to disconnect it.
  11. HP Omni 10  Speaker Replacement: paso 11, imagen 1 de 1
    • Lift the speaker set out of their sockets.
    • The speakers will also be attached via adhesive. They may be difficult to remove by hand.
  12. HP Omni 10  Speaker Replacement: paso 12, imagen 1 de 1
    • Unhook the left speaker's connector wire to fully remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Alex Miller
Miembro Desde 10/11/16
345 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Leahy Fall 2016 Miembro de USF Tampa, Team 1-1, Leahy Fall 2016
USFT-LEAHY-F16S1G1
3 Miembros
10 Guías creadas
Un comentario
its order when i will get it please candly I request
Abdul Raheem - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 608
