Saltar al contenido principal
HP Omen 15-CE0XX Fan Replacement
Qué necesitas
  1. HP Omen 15-CE0XX Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 5.5 mm screws from the bottom cover.
  2. HP Omen 15-CE0XX Fan Replacement: paso 2, imagen 1 de 2 HP Omen 15-CE0XX Fan Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to gently separate the bottom cover from the main chassis, and pull the cover upwards.
  3. HP Omen 15-CE0XX Fan Replacement: paso 3, imagen 1 de 2 HP Omen 15-CE0XX Fan Replacement: paso 3, imagen 2 de 2
    • Unscrew the four 5.5 mm screws that connect the battery to the main system, and gently detach the battery.
    • While removing, make sure to avoid pulling the battery straight out. Instead gently lift the lower half of the battery and slide it away from the motherboard in an away and upwards motion.
  4. HP Omen 15-CE0XX Fan Replacement: paso 4, imagen 1 de 2 HP Omen 15-CE0XX Fan Replacement: paso 4, imagen 2 de 2
    • Remove the trunk outlet for the replacement fan. This is done by unscrewing the three 5.5mm screws on the trunk outlet and then sliding it outwards to remove.
  5. HP Omen 15-CE0XX Fan Replacement: paso 5, imagen 1 de 2 HP Omen 15-CE0XX Fan Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the five 5.5 mm screws that secure the bracket to the frame.
    • After all screws are loose, gently lift the bracket upwards.
    • Be careful with the power cable sitting right under this bracket. You might have to move the cable around gently to get the bracket out
  6. HP Omen 15-CE0XX Fan Replacement: paso 6, imagen 1 de 1
    • Disconnect the fan cable from the motherboard using a plastic opening/ pry tool.
    • Do not use too much force while pulling the fan cable as it may break. If required, you may use a secondary plastic opening/pry tool for support.
  7. HP Omen 15-CE0XX Fan Replacement: paso 7, imagen 1 de 1
    • Carefully pull the fan out, clean the dust if required.
    • Finally, you can now replace the faulty fan with the new fan by following the above steps in reverse order.
Conclusión
Una persona más ha completado esta guía.
Nadim Patel
Miembro Desde 01/27/23
154 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 75
Todo El Tiempo: 1,096
