Saltar al contenido principal
HP Omen 15-5002xx Battery Replacement
Qué necesitas
  1. HP Omen 15-5002xx Battery Replacement, Back Cover: paso 1, imagen 1 de 2 HP Omen 15-5002xx Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Battery Replacement: paso 3, imagen 1 de 2 HP Omen 15-5002xx Battery Replacement: paso 3, imagen 2 de 2
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
Conclusión
Equipo
Gateway, Team 1-1, Saknee Fall 2021 Miembro de Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 539
