Saltar al contenido principal
HP Officejet Pro 8625 Power Supply Replacement
Qué necesitas
  1. HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: paso 1, imagen 1 de 3 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: paso 1, imagen 2 de 3 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: paso 1, imagen 3 de 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Power Supply Replacement: paso 2, imagen 1 de 3 HP Officejet Pro 8625 Power Supply Replacement: paso 2, imagen 2 de 3 HP Officejet Pro 8625 Power Supply Replacement: paso 2, imagen 3 de 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Power Supply Replacement: paso 3, imagen 1 de 2 HP Officejet Pro 8625 Power Supply Replacement: paso 3, imagen 2 de 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Power Supply Replacement, Power Supply: paso 4, imagen 1 de 3 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: paso 4, imagen 2 de 3 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: paso 4, imagen 3 de 3
    • Remove the the black cable from the bottom of the motherboard by carefully pulling down on the connection.
  5. HP Officejet Pro 8625 Power Supply Replacement: paso 5, imagen 1 de 2 HP Officejet Pro 8625 Power Supply Replacement: paso 5, imagen 2 de 2
    • Remove the two 9.3 mm T9 screws that attach the power supply to the bottom of the printer.
  6. HP Officejet Pro 8625 Power Supply Replacement: paso 6, imagen 1 de 2 HP Officejet Pro 8625 Power Supply Replacement: paso 6, imagen 2 de 2
    • Slide the power supply out of the printer by pulling towards you.
    • Be careful of the wires coming from the motherboard.
Conclusión
2 personas más completaron esta guía.
Cole Andrews
Miembro Desde 10/08/18
273 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G3, White Fall 2018 Miembro de Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 481
