Saltar al contenido principal
HP Officejet Pro 8625 Motherboard Replacement
Qué necesitas
  1. HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: paso 1, imagen 1 de 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: paso 1, imagen 2 de 3 HP Officejet Pro 8625 Motherboard Replacement, Left Side Panel: paso 1, imagen 3 de 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Motherboard Replacement: paso 2, imagen 1 de 3 HP Officejet Pro 8625 Motherboard Replacement: paso 2, imagen 2 de 3 HP Officejet Pro 8625 Motherboard Replacement: paso 2, imagen 3 de 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Motherboard Replacement: paso 3, imagen 1 de 2 HP Officejet Pro 8625 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 HP Officejet Pro 8625 Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 Motherboard Replacement: paso 5, imagen 1 de 2 HP Officejet Pro 8625 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 Motherboard Replacement: paso 6, imagen 1 de 3 HP Officejet Pro 8625 Motherboard Replacement: paso 6, imagen 2 de 3 HP Officejet Pro 8625 Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
Conclusión
Cam Engle
Miembro Desde 10/08/18
555 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S13-G3, White Fall 2018 Miembro de Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 519
