Introducción
If the display on your printer is no longer working, you may need to replace it. This guide will show you how. You will need a T9 Torx screwdriver and a T6 Torx screwdriver to remove the screws in this guide.
Qué necesitas
Disconnect the display by holding it in place while pulling down on the plastic hinge.
Remove the four 4.8 mm screws from the back of the display using a T6 screwdriver.
Casi Terminas!
Conclusión
