Saltar al contenido principal
HP Officejet Pro 8620 Power Adapter Replacement
Qué necesitas
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: paso 1, imagen 1 de 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: paso 1, imagen 2 de 3 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: paso 1, imagen 3 de 3
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: paso 2, imagen 1 de 2 HP Officejet Pro 8620 Power Adapter Replacement: paso 2, imagen 2 de 2
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: paso 3, imagen 1 de 2 HP Officejet Pro 8620 Power Adapter Replacement: paso 3, imagen 2 de 2
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: paso 4, imagen 1 de 3 HP Officejet Pro 8620 Power Adapter Replacement: paso 4, imagen 2 de 3 HP Officejet Pro 8620 Power Adapter Replacement: paso 4, imagen 3 de 3
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: paso 5, imagen 1 de 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: paso 5, imagen 2 de 3 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: paso 5, imagen 3 de 3
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: paso 6, imagen 1 de 3 HP Officejet Pro 8620 Power Adapter Replacement: paso 6, imagen 2 de 3 HP Officejet Pro 8620 Power Adapter Replacement: paso 6, imagen 3 de 3
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: paso 7, imagen 1 de 1
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: paso 8, imagen 1 de 1
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Conclusión
Scott
Miembro Desde 01/24/18
593 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S19-G2, Livingston Spring 2018 Miembro de Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Miembro
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 2,184
