Saltar al contenido principal
HP Officejet Pro 8620 Display Replacement
Qué necesitas
  1. HP Officejet Pro 8620 Display Replacement, Display: paso 1, imagen 1 de 2 HP Officejet Pro 8620 Display Replacement, Display: paso 1, imagen 2 de 2
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: paso 2, imagen 1 de 3 HP Officejet Pro 8620 Display Replacement: paso 2, imagen 2 de 3 HP Officejet Pro 8620 Display Replacement: paso 2, imagen 3 de 3
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: paso 3, imagen 1 de 3 HP Officejet Pro 8620 Display Replacement: paso 3, imagen 2 de 3 HP Officejet Pro 8620 Display Replacement: paso 3, imagen 3 de 3
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: paso 4, imagen 1 de 2 HP Officejet Pro 8620 Display Replacement: paso 4, imagen 2 de 2
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
Conclusión
4 personas más completaron esta guía.
Dallas Rocha
Miembro Desde 01/24/18
243 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S19-G2, Livingston Winter 2018 Miembro de Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 22
Todo El Tiempo: 4,858
