Saltar al contenido principal
HP Officejet Pro 6835 Speaker Replacement
Qué necesitas
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: paso 1, imagen 1 de 1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: paso 2, imagen 1 de 3 HP Officejet Pro 6835 Speaker Replacement: paso 2, imagen 2 de 3 HP Officejet Pro 6835 Speaker Replacement: paso 2, imagen 3 de 3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: paso 3, imagen 1 de 1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: paso 4, imagen 1 de 2 HP Officejet Pro 6835 Speaker Replacement: paso 4, imagen 2 de 2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: paso 5, imagen 1 de 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: paso 5, imagen 2 de 3 HP Officejet Pro 6835 Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: paso 6, imagen 1 de 1
    • Carefully slide the speaker out of the printer.
Conclusión
David J
Miembro Desde 01/24/18
169 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S2-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 271
