Saltar al contenido principal
HP Officejet Pro 6835 Encoder Strip Replacement
Qué necesitas
  1. HP Officejet Pro 6835 Encoder Strip Replacement, HP Officejet Pro 6835 Cover Disassembly: paso 1, imagen 1 de 1
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Encoder Strip Replacement: paso 2, imagen 1 de 3 HP Officejet Pro 6835 Encoder Strip Replacement: paso 2, imagen 2 de 3 HP Officejet Pro 6835 Encoder Strip Replacement: paso 2, imagen 3 de 3
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Encoder Strip Replacement: paso 3, imagen 1 de 1
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Encoder Strip Replacement: paso 4, imagen 1 de 2 HP Officejet Pro 6835 Encoder Strip Replacement: paso 4, imagen 2 de 2
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: paso 5, imagen 1 de 2 HP Officejet Pro 6835 Encoder Strip Replacement, Encoder Strip: paso 5, imagen 2 de 2
    • Push the hook that is attached to the encoder strip towards the center of the printer.
    • Hold the hook pushed in and pull the strip off of the hook.
    • Repeat on the other side of the encoder strip.
    • During reassembly, the black triangle on the encoder strip should be on the right side of the printer.
  6. HP Officejet Pro 6835 Encoder Strip Replacement: paso 6, imagen 1 de 1
    • Carefully slide the encoder strip out from the carriage.
Conclusión
David J
Miembro Desde 01/24/18
169 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S2-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 24
Todo El Tiempo: 1,932
