Introducción
Is the glass plate in your printer broken? Consider using this guide to replace the glass plate in your printer.
Partes
No se requieren partes.
  1. Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
    • Remove the controlling keyboard with hands.
    • Using fingers to open the back cover board of the glass plate.
    • Remove the 10mm screw on the right of the board with T8 torx security screwdriver.
    • Remove the part that is under the 10mm screw.
    • Remove the glass plate with hands.
Conclusión
Jiayin Zhu
Miembro Desde 21/10/18
349 Reputación
3 Guías creadas
Equipo
UC Davis, Team S11-G8, Lore Fall 2018 Miembro de UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
3 Miembros
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 10
Todo El Tiempo: 26
