Saltar al contenido principal
HP Officejet J3680 Phone Cord Replacement
Qué necesitas
  1. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from handset: paso 1, imagen 1 de 1
    • Unplug one end of the cord by squeezing the plastic piece and pulling it out from the handset as shown on the left.
  2. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from back of device: paso 2, imagen 1 de 1
    • Turn the device over to see the bottom as shown on the left.
    • First, slide the cord out from under the plastic clip.
    • Then as done in step one, squeeze the plastic piece to remove it from the back of the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. You will know the plastic piece has been inserted correctly if you hear it click into place.
Marisa
Miembro Desde 10/22/14
206 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 1-1, Duarte Fall 2014
UMASSD-DUARTE-F14S1G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 231
