Qué necesitas
Remove the plug from the outlet and from the back of the device
Remove the USB Cable from your computer and from the back of the device.
Using your Torx T10 screwdriver, remove the screws indicated in the picture. Screws are 13mm in length.
In step 2, you removed the screw from the blue indicated area.
Gently pop off the black cover that the phone rests on. Underneath this cover, you will find two more screws.
Once the rear plastic panel has been removed, you are ready to replace and repair the necessary parts.
Using your Torx t10 screwdriver, remove the 4 screws that hold the main motherboard to the device. Screws are 13mm in length.
Once removed, the main motherboard will be free from the device. You will notice that on the lefthand side, three of the screws hold down green wires. Make sure when replacing the motherboard that you screw these back into place.
Una persona más ha completado esta guía.
