Introducción
The touchscreen is what you use to interact with the printer. If the touchscreen is malfunctioning, the HP OfficeJet 4650's interactive functions will not work. This guide will show you how to replace the touchscreen.
Qué necesitas
Open the cartridge access door by using putting one hand on the grooves of each side and pulling up.
Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the screen to the printer body by turning the screws counterclockwise.
Using the Torx T6 hex screwdriver, remove the 7.0mm screws that bind the green circuit board to the screen by turning the screws counterclockwise.
Una persona más ha completado esta guía.
2 comentarios
Where do I buy the replacement screen
Where can you buy a replacement screen
