Saltar al contenido principal
HP OfficeJet 4650 Paper Tray Replacement
Qué necesitas
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: paso 1, imagen 1 de 2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: paso 1, imagen 2 de 2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: paso 2, imagen 1 de 2 HP OfficeJet 4650 Paper Tray Replacement: paso 2, imagen 2 de 2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: paso 3, imagen 1 de 3 HP OfficeJet 4650 Paper Tray Replacement: paso 3, imagen 2 de 3 HP OfficeJet 4650 Paper Tray Replacement: paso 3, imagen 3 de 3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: paso 4, imagen 1 de 2 HP OfficeJet 4650 Paper Tray Replacement: paso 4, imagen 2 de 2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: paso 5, imagen 1 de 1
    • Remove the paper tray by pulling the tray away from the printer.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S19-G6, Livingston Winter 2018 Miembro de Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
Miembros de 3
10 Guías creadas
4 comentarios
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Contestar
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Contestar
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Contestar
accidentally pulled the tray out completely. guide was excellent showing me how to get it back in.
walter harrington - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 49
Todo El Tiempo: 4,906
