Saltar al contenido principal
HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement
Qué necesitas
  1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: paso 1, imagen 1 de 2 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: paso 1, imagen 2 de 2
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • The document feeder is designed to be a bit more difficult to open, so it is okay to use a little more force.
  2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 2, imagen 1 de 3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 2, imagen 2 de 3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 2, imagen 3 de 3
    • Locate the manual one-inch paper-feed roller end of the document feeder cover.
    • Remove the 11.0mm screw on the side of the roller with 2.0mm hex screwdriver.
  3. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 3, imagen 1 de 3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 3, imagen 2 de 3 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: paso 3, imagen 3 de 3
    • Pull the side cover of the manual one-inch paper-feed roller to the right and remove the paper roller.
Conclusión
Equipo
Cal Poly, Team S19-G6, Livingston Winter 2018 Miembro de Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 1,831
