Saltar al contenido principal
HP Notebook 15-ba018ds RAM Replacement
Qué necesitas
  1. HP Notebook 15-ba018ds RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds RAM Replacement: paso 2, imagen 1 de 3 HP Notebook 15-ba018ds RAM Replacement: paso 2, imagen 2 de 3 HP Notebook 15-ba018ds RAM Replacement: paso 2, imagen 3 de 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds RAM Replacement, RAM: paso 3, imagen 1 de 2 HP Notebook 15-ba018ds RAM Replacement, RAM: paso 3, imagen 2 de 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that you unscrew.
  4. HP Notebook 15-ba018ds RAM Replacement: paso 4, imagen 1 de 1
    • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
    • On the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds RAM Replacement: paso 5, imagen 1 de 3 HP Notebook 15-ba018ds RAM Replacement: paso 5, imagen 2 de 3 HP Notebook 15-ba018ds RAM Replacement: paso 5, imagen 3 de 3
    • This laptop has one RAM.
    • Gently pull out the RAM from the socket.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,207
