Saltar al contenido principal
HP Notebook 15-ba018ds Fan Replacement
Qué necesitas
  1. HP Notebook 15-ba018ds Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Fan Replacement: paso 2, imagen 1 de 3 HP Notebook 15-ba018ds Fan Replacement: paso 2, imagen 2 de 3 HP Notebook 15-ba018ds Fan Replacement: paso 2, imagen 3 de 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Fan Replacement, Fan: paso 3, imagen 1 de 2 HP Notebook 15-ba018ds Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Fan Replacement: paso 4, imagen 1 de 1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Fan Replacement: paso 5, imagen 1 de 2 HP Notebook 15-ba018ds Fan Replacement: paso 5, imagen 2 de 2
    • Remove the three Phillips head screws attached to the fan.
  6. HP Notebook 15-ba018ds Fan Replacement: paso 6, imagen 1 de 2 HP Notebook 15-ba018ds Fan Replacement: paso 6, imagen 2 de 2
    • Remove old fan and replace with a new fan.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,321
