Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
  1. Locate the screws highlighted to remove. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
    • Locate the screws highlighted to remove.
    • We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
  2. Remove the middle back lid shown in the image. May require a bit of force. If it is not coming out try the other side.
    • Remove the middle back lid shown in the image.
    • May require a bit of force. If it is not coming out try the other side.
  3. Go around the edges with a special tool to pop lid out of place.
    • Go around the edges with a special tool to pop lid out of place.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Once all corners are popped out of place lift the cover up slowly.
    • Once all corners are popped out of place lift the cover up slowly.
    • Lifting the lid should not require much force.
  6. Locate the battery port.
    • Locate the battery port.
    • refer to the "Lower case disassembly" guide to show you how to safely remove the back of the laptop.
  7. Remove the screw next to the battery port. Gently pull out the charging port.
    • Remove the screw next to the battery port.
    • Gently pull out the charging port.
  8. Unplug the connector shown in the image. This should not require much force. Unplug the connector shown in the image. This should not require much force.
    • Unplug the connector shown in the image. This should not require much force.
Conclusión
Raul Rodriguez
Miembro Desde 27/02/18
289 Reputación
3 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 45
