Saltar al contenido principal
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
Qué necesitas
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: paso 1, imagen 1 de 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: paso 1, imagen 2 de 2
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 2, imagen 1 de 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 2, imagen 2 de 2
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 3, imagen 1 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 3, imagen 2 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 3, imagen 3 de 3
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 4, imagen 1 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 4, imagen 2 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: paso 4, imagen 3 de 3
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 424
