Saltar al contenido principal
HP Mobile Thin Client mt41 Fan Replacement
Qué necesitas
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: paso 1, imagen 1 de 2 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: paso 2, imagen 1 de 2 HP Mobile Thin Client mt41 Fan Replacement: paso 2, imagen 2 de 2
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: paso 3, imagen 1 de 1
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: paso 4, imagen 1 de 1
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: paso 5, imagen 1 de 2 HP Mobile Thin Client mt41 Fan Replacement, Fan: paso 5, imagen 2 de 2
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: paso 6, imagen 1 de 1
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: paso 7, imagen 1 de 1
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 352
