Introducción
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
Partes
No se requieren partes.
  1. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
    Agregar Comentario
  2. Slide the battery away from the device to remove.
    • Slide the battery away from the device to remove.
    Agregar Comentario
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Lift the memory shield up and remove from the laptop.
    Agregar Comentario
    • Begin by removing the red and blue wires from the wireless card.
    • Gently remove to avoid damaging the ends of the wires.
    Agregar Comentario
    • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
    Agregar Comentario
    • Lift up the unattached side of the wireless card and pull out to remove.
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 1,014
