Saltar al contenido principal
HP Mini 311 RAM Replacement
Qué necesitas
  1. HP Mini 311 RAM Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 311 RAM Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 311 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 RAM Replacement: paso 2, imagen 1 de 2 HP Mini 311 RAM Replacement: paso 2, imagen 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 RAM Replacement, Memory Shield: paso 3, imagen 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 RAM Replacement: paso 4, imagen 1 de 2 HP Mini 311 RAM Replacement: paso 4, imagen 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 RAM Replacement, RAM: paso 5, imagen 1 de 3 HP Mini 311 RAM Replacement, RAM: paso 5, imagen 2 de 3 HP Mini 311 RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
Miembros de 4
10 Guías creadas
2 comentarios
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Contestar
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 3,745
