Introducción
If you have experienced a malfunction with your keys or overall keyboard, you should change the entire keyboard on your HP Mini 311.
Qué necesitas
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
4 personas más completaron esta guía.
