Introducción
The Real Time Clock (RTC) Battery helps to retain important BIOS settings such as system time, date, and BIOS configuration while the laptop is turned off or when the main battery is removed.
Herramientas
Partes
No se requieren partes.
Close the laptop and turn it over, so that the underside is up and the silver battery bay is facing towards you.
Locate the RTC battery, a thin cylinder near the bottom left corner of the computer.
Locate the RTC Battery Cable, connected to the RTC Battery.
Pull the RTC battery cable to to the left, out of its socket.
2 personas más completaron esta guía.
