Saltar al contenido principal
HP Mini 210-2070NR Keyboard Replacement
Qué necesitas
  1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: paso 1, imagen 1 de 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Keyboard Replacement: paso 2, imagen 1 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 2, imagen 2 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 2, imagen 3 de 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Keyboard Replacement: paso 3, imagen 1 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 3, imagen 2 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 3, imagen 3 de 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Keyboard Replacement: paso 4, imagen 1 de 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR Keyboard Replacement, Keyboard: paso 5, imagen 1 de 2 HP Mini 210-2070NR Keyboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
    • Each of the screws are labeled with small keyboards next to them.
    • Flip the computer over so that the front is facing you.
  6. HP Mini 210-2070NR Keyboard Replacement: paso 6, imagen 1 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 6, imagen 2 de 3 HP Mini 210-2070NR Keyboard Replacement: paso 6, imagen 3 de 3
    • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
    • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
    • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
    • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
  7. HP Mini 210-2070NR Keyboard Replacement: paso 7, imagen 1 de 2 HP Mini 210-2070NR Keyboard Replacement: paso 7, imagen 2 de 2
    • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
    • Pull the keyboard cable out of its socket to disconnect it.
  8. HP Mini 210-2070NR Keyboard Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard by lifting it away from the computer.
Conclusión
Sean Kuster
Miembro Desde 10/05/12
91 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-23, Amido Fall 2012 Miembro de Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,611
