Saltar al contenido principal
HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: paso 1, imagen 1 de 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 2, imagen 1 de 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 2, imagen 2 de 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 2, imagen 3 de 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 3, imagen 1 de 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 3, imagen 2 de 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 3, imagen 3 de 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: paso 4, imagen 1 de 1
    • Orient the computer as shown in the picture.
Conclusión
2 personas más completaron esta guía.
Sean Kuster
Miembro Desde 10/05/12
91 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-23, Amido Fall 2012 Miembro de Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 1,454
