Saltar al contenido principal
HP Mini 210-1199DX Wireless Card Replacement
Qué necesitas
  1. HP Mini 210-1199DX Wireless Card Replacement, Battery: paso 1, imagen 1 de 2 HP Mini 210-1199DX Wireless Card Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Wireless Card Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Wireless Card Replacement, Bottom Cover: paso 3, imagen 1 de 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Wireless Card Replacement: paso 4, imagen 1 de 3 HP Mini 210-1199DX Wireless Card Replacement: paso 4, imagen 2 de 3 HP Mini 210-1199DX Wireless Card Replacement: paso 4, imagen 3 de 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Wireless Card Replacement: paso 5, imagen 1 de 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX Wireless Card Replacement, Wireless Card: paso 6, imagen 1 de 1
    • Locate the Wireless Card.
  7. HP Mini 210-1199DX Wireless Card Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • With fingers or tweezers, carefully pull the black and white wire connectors from their sockets and move them to the side.
  8. HP Mini 210-1199DX Wireless Card Replacement: paso 8, imagen 1 de 2 HP Mini 210-1199DX Wireless Card Replacement: paso 8, imagen 2 de 2
    • With a Phillip's Screwdriver, firmly but slowly remove the two screws from the top of the wireless card.
    • Be careful not to strip the nail head.
  9. HP Mini 210-1199DX Wireless Card Replacement: paso 9, imagen 1 de 1
    • Pull the wireless card out.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 406
