Saltar al contenido principal
HP Mini 210-1199DX CMOS Battery Replacement
Qué necesitas
  1. HP Mini 210-1199DX CMOS Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Mini 210-1199DX CMOS Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX CMOS Battery Replacement, Bottom Cover: paso 3, imagen 1 de 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX CMOS Battery Replacement: paso 4, imagen 1 de 3 HP Mini 210-1199DX CMOS Battery Replacement: paso 4, imagen 2 de 3 HP Mini 210-1199DX CMOS Battery Replacement: paso 4, imagen 3 de 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX CMOS Battery Replacement: paso 5, imagen 1 de 1
    • Pull the case off of the device
  6. HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: paso 6, imagen 1 de 2 HP Mini 210-1199DX CMOS Battery Replacement, CMOS Battery: paso 6, imagen 2 de 2
    • Simply pull the small black ribbon off of the battery with either your finger or a pair of tweezers.
  7. HP Mini 210-1199DX CMOS Battery Replacement: paso 7, imagen 1 de 2 HP Mini 210-1199DX CMOS Battery Replacement: paso 7, imagen 2 de 2
    • Using the spudger, carefully pop the battery out of the right side as seen in the picture.
    • To reinstall, carefully place slide the battery back into place with the positive side facing upwards.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 677
