Saltar al contenido principal
HP Mini 110-3735dx Screen Replacement
Qué necesitas
  1. HP Mini 110-3735dx Screen Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement, Battery: paso 1, imagen 3 de 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Screen Replacement: paso 2, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 2, imagen 2 de 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Screen Replacement, Backcover: paso 3, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement, Backcover: paso 3, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement, Backcover: paso 3, imagen 3 de 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Screen Replacement, Keyboard: paso 4, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Screen Replacement: paso 5, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 5, imagen 2 de 2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Screen Replacement: paso 6, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 6, imagen 2 de 2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Screen Replacement: paso 7, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 7, imagen 2 de 2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Screen Replacement: paso 8, imagen 1 de 1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Screen Replacement: paso 9, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 9, imagen 2 de 2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Screen Replacement: paso 10, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 10, imagen 2 de 2
    • Gently pull the keyboard cable from the socket.
  11. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: paso 11, imagen 1 de 1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  12. HP Mini 110-3735dx Screen Replacement: paso 12, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 12, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 12, imagen 3 de 3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  13. HP Mini 110-3735dx Screen Replacement: paso 13, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 13, imagen 2 de 2
    • Unplug the cable connecting to the hard drive.
  14. HP Mini 110-3735dx Screen Replacement, Screen: paso 14, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement, Screen: paso 14, imagen 2 de 2
    • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
  15. HP Mini 110-3735dx Screen Replacement: paso 15, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 15, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 15, imagen 3 de 3
    • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
  16. HP Mini 110-3735dx Screen Replacement: paso 16, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 16, imagen 2 de 2
    • Remove the two connectors for the motherboard from their sockets.
  17. HP Mini 110-3735dx Screen Replacement: paso 17, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 17, imagen 2 de 2
    • Close the laptop by bringing the screen down.
    • Flip the laptop over to the other side.
  18. HP Mini 110-3735dx Screen Replacement: paso 18, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 18, imagen 2 de 2
    • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
  19. HP Mini 110-3735dx Screen Replacement: paso 19, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 19, imagen 2 de 2
    • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
    • Located on the left and right side where the battery was removed.
  20. HP Mini 110-3735dx Screen Replacement: paso 20, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 20, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 20, imagen 3 de 3
    • Pull the black plastic pieces that the screws was holding inward.
    • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
  21. HP Mini 110-3735dx Screen Replacement: paso 21, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 21, imagen 2 de 2
    • Flip the laptop back over.
    • Open it by lifting the screeen.
  22. HP Mini 110-3735dx Screen Replacement: paso 22, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 22, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 22, imagen 3 de 3
    • Right next to the previous plastic piece, remove the other two plastic pieces.
    • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
  23. HP Mini 110-3735dx Screen Replacement: paso 23, imagen 1 de 1
    • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
    • Start along the speaker grill near the touch pad, and move along the sides.
  24. HP Mini 110-3735dx Screen Replacement: paso 24, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 24, imagen 2 de 2
    • Lift up the front plate where the keyboard was.
  25. HP Mini 110-3735dx Screen Replacement: paso 25, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 25, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 25, imagen 3 de 3
    • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
    • Move the cable.
  26. HP Mini 110-3735dx Screen Replacement: paso 26, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 26, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 26, imagen 3 de 3
    • Remove the webcam cables from the motherboard.
    • Located on the back side of the laptop in the bottom left corner.
  27. HP Mini 110-3735dx Screen Replacement: paso 27, imagen 1 de 1
    • Flip over the computer, and open the laptop.
    • Lift up the front plate on the top right corner.
  28. HP Mini 110-3735dx Screen Replacement: paso 28, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 28, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 28, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pull the cables for the web cam out using tweezers.
  29. HP Mini 110-3735dx Screen Replacement: paso 29, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 29, imagen 2 de 2
    • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
  30. HP Mini 110-3735dx Screen Replacement: paso 30, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 30, imagen 2 de 2
    • Remove the black plastic piece that the screw was holding on both sides.
    • This will reveal another screw.
  31. HP Mini 110-3735dx Screen Replacement: paso 31, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 31, imagen 2 de 2
    • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
    • When removing, keep hold of the screen to make sure it doesn't fall.
  32. HP Mini 110-3735dx Screen Replacement: paso 32, imagen 1 de 1
    • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
    • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
  33. HP Mini 110-3735dx Screen Replacement: paso 33, imagen 1 de 3 HP Mini 110-3735dx Screen Replacement: paso 33, imagen 2 de 3 HP Mini 110-3735dx Screen Replacement: paso 33, imagen 3 de 3
    • Remove the front plate.
    • Pull the cables through the holes.
  34. HP Mini 110-3735dx Screen Replacement: paso 34, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 34, imagen 2 de 2
    • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
  35. HP Mini 110-3735dx Screen Replacement: paso 35, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 35, imagen 2 de 2
    • Lift the screen up.
  36. HP Mini 110-3735dx Screen Replacement: paso 36, imagen 1 de 2 HP Mini 110-3735dx Screen Replacement: paso 36, imagen 2 de 2
    • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
Conclusión
Equipo
Un comentario
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 801
