Saltar al contenido principal
HP Mini 110-3735dx Keyboard Replacement
Qué necesitas
  1. HP Mini 110-3735dx Keyboard Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 110-3735dx Keyboard Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 110-3735dx Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Keyboard Replacement: paso 2, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 2, imagen 2 de 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Keyboard Replacement, Backcover: paso 3, imagen 1 de 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: paso 3, imagen 2 de 3 HP Mini 110-3735dx Keyboard Replacement, Backcover: paso 3, imagen 3 de 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Keyboard Replacement: paso 5, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Keyboard Replacement: paso 6, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 6, imagen 2 de 2
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Keyboard Replacement: paso 7, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 7, imagen 2 de 2
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Keyboard Replacement: paso 8, imagen 1 de 1
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Keyboard Replacement: paso 9, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 9, imagen 2 de 2
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Keyboard Replacement: paso 10, imagen 1 de 2 HP Mini 110-3735dx Keyboard Replacement: paso 10, imagen 2 de 2
    • Gently pull the keyboard cable from the socket.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 714
