Saltar al contenido principal
HP Mini 110-3735dx Hard Drive Replacement
Qué necesitas
  1. HP Mini 110-3735dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 110-3735dx Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 110-3735dx Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Hard Drive Replacement: paso 2, imagen 1 de 2 HP Mini 110-3735dx Hard Drive Replacement: paso 2, imagen 2 de 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Hard Drive Replacement, Backcover: paso 3, imagen 1 de 3 HP Mini 110-3735dx Hard Drive Replacement, Backcover: paso 3, imagen 2 de 3 HP Mini 110-3735dx Hard Drive Replacement, Backcover: paso 3, imagen 3 de 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive Cage: paso 4, imagen 1 de 1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Hard Drive Replacement: paso 5, imagen 1 de 3 HP Mini 110-3735dx Hard Drive Replacement: paso 5, imagen 2 de 3 HP Mini 110-3735dx Hard Drive Replacement: paso 5, imagen 3 de 3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  6. HP Mini 110-3735dx Hard Drive Replacement: paso 6, imagen 1 de 2 HP Mini 110-3735dx Hard Drive Replacement: paso 6, imagen 2 de 2
    • Unplug the cable connecting to the hard drive.
  7. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 3 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: paso 7, imagen 2 de 3 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: paso 7, imagen 3 de 3
    • Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
  8. HP Mini 110-3735dx Hard Drive Replacement: paso 8, imagen 1 de 3 HP Mini 110-3735dx Hard Drive Replacement: paso 8, imagen 2 de 3 HP Mini 110-3735dx Hard Drive Replacement: paso 8, imagen 3 de 3
    • Gently remove the hard drive from it's cage.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 620
