Introducción
This guide provides direction for learning how to best replace the touchpad for the HP Mini 110-3131dx. In order to do this project, you will need iFixit Opening Tool, a Phillips #1 Screwdriver, and a Phillips #0 Screwdriver. Before you start, be sure to power off your HP Mini 110-3131dx. Best of luck!
Qué necesitas
Power off the laptop before trying to remove the battery.
Turn the laptop upside down, and locate the sliding tabs on the battery.
Slide both tabs in an inward direction, then slide the battery away from the laptop.
Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
Flip the laptop over and remove the six black screws.
Turn the keyboard so that the touchpad is close to you.
Detach the ribbon cable from the connector on the touchpad circuit board using your fingernail or an opening tool.
Remove the four 2.9 mm screws from the bracket using a Phillips #0 screwdriver.
Remove the touchpad from the top of the keyboard bezel on the touch-sensitive side.
Una persona más ha completado esta guía.
