Saltar al contenido principal
HP Mini 110-3131dx Screen Replacement
Qué necesitas
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Screen Replacement, Screen: paso 2, imagen 1 de 3 HP Mini 110-3131dx Screen Replacement, Screen: paso 2, imagen 2 de 3 HP Mini 110-3131dx Screen Replacement, Screen: paso 2, imagen 3 de 3
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
Conclusión
Una persona más ha completado esta guía.
aarondcollege
Miembro Desde 10/06/16
1,297 Reputación
10 Guías creadas
Equipo
USF Tampa, Team 2-4, Cagle Fall 2016 Miembro de USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 480
