Saltar al contenido principal
HP Mini 110-3131dx Hard Drive Replacement
Qué necesitas
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: paso 2, imagen 1 de 2 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: paso 2, imagen 2 de 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: paso 4, imagen 1 de 2 HP Mini 110-3131dx Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
Conclusión
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 personas más completaron esta guía.
aarondcollege
Miembro Desde 10/06/16
1,297 Reputación
10 Guías creadas
Equipo
USF Tampa, Team 2-4, Cagle Fall 2016 Miembro de USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,389
