Saltar al contenido principal
HP Mini 110-1046NR Memory Card Replacement
Qué necesitas
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 110-1046NR Memory Card Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 110-1046NR Memory Card Replacement, Battery: paso 1, imagen 3 de 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: paso 2, imagen 1 de 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: paso 2, imagen 2 de 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: paso 2, imagen 3 de 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: paso 3, imagen 1 de 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: paso 3, imagen 2 de 3 HP Mini 110-1046NR Memory Card Replacement, Memory Card: paso 3, imagen 3 de 3
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Conclusión
2 personas más completaron esta guía.
Jared Cooper
Miembro Desde 10/18/13
649 Reputación
5 Guías creadas
Equipo
Clemson, Team 14-1, Benson Fall 2013 Miembro de Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 1,295
