Saltar al contenido principal
HP Mini 110-1046NR Keyboard Replacement
Qué necesitas
  1. HP Mini 110-1046NR Keyboard Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 110-1046NR Keyboard Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 110-1046NR Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Keyboard Replacement, Keyboard: paso 2, imagen 1 de 2 HP Mini 110-1046NR Keyboard Replacement, Keyboard: paso 2, imagen 2 de 2
    • With the screen closed, turn your netbook around so that the battery slot is facing you.
    • Remove the three 2.9mm screws in the battery slot.
    • This step can be made easier by using a magnetic screwdriver.
  3. HP Mini 110-1046NR Keyboard Replacement: paso 3, imagen 1 de 3 HP Mini 110-1046NR Keyboard Replacement: paso 3, imagen 2 de 3 HP Mini 110-1046NR Keyboard Replacement: paso 3, imagen 3 de 3
    • Flip the netbook upright, and open the screen as far as it will go.
    • Pry up the keyboard from the middle of the top edge.
    • Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
    • Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
    • Do not pull the keyboard out immediately - there is a potentially fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-1046NR Keyboard Replacement: paso 4, imagen 1 de 3 HP Mini 110-1046NR Keyboard Replacement: paso 4, imagen 2 de 3 HP Mini 110-1046NR Keyboard Replacement: paso 4, imagen 3 de 3
    • Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
    • Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
    • Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
Conclusión
2 personas más completaron esta guía.
Amos Hine
Miembro Desde 10/18/13
1,275 Reputación
7 Guías creadas
Equipo
Clemson, Team 14-1, Benson Fall 2013 Miembro de Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 6,481
