Introducción
Removal of the front cover of the HP Media Center 876x tower is required before many other repairs can be performed. The front cover houses many of the computers ports and drives and must be removed for proper repair of these drives.
Qué necesitas
Orient the tower vertically.
Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
Slide the side panel out of its notches, and pull it gently off of the tower.
