Introducción
These steps will show how to replace the power plug from the printer. This guide may be used if the prongs of the plug are broken or if a new power supply is needed all together.
Qué necesitas
Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
The power plug will be held together with one Phillips screw 7mm and wire connection.
3 personas más completaron esta guía.
