Saltar al contenido principal
HP LaserJet P1102w Power Plug Replacement
Qué necesitas
  1. HP LaserJet P1102w Power Plug Replacement, Left Side Panel: paso 1, imagen 1 de 3 HP LaserJet P1102w Power Plug Replacement, Left Side Panel: paso 1, imagen 2 de 3 HP LaserJet P1102w Power Plug Replacement, Left Side Panel: paso 1, imagen 3 de 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Power Plug Replacement: paso 2, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement: paso 2, imagen 2 de 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Power Plug Replacement: paso 3, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement: paso 3, imagen 2 de 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Power Plug Replacement: paso 4, imagen 1 de 3 HP LaserJet P1102w Power Plug Replacement: paso 4, imagen 2 de 3 HP LaserJet P1102w Power Plug Replacement: paso 4, imagen 3 de 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Power Plug Replacement: paso 5, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement: paso 5, imagen 2 de 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Power Plug Replacement: paso 6, imagen 1 de 3 HP LaserJet P1102w Power Plug Replacement: paso 6, imagen 2 de 3 HP LaserJet P1102w Power Plug Replacement: paso 6, imagen 3 de 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Power Plug Replacement: paso 7, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement: paso 7, imagen 2 de 2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Power Plug Replacement, Power Plug: paso 8, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement, Power Plug: paso 8, imagen 2 de 2
    • The power plug will be held together with one Phillips screw 7mm and wire connection.
  9. HP LaserJet P1102w Power Plug Replacement: paso 9, imagen 1 de 2 HP LaserJet P1102w Power Plug Replacement: paso 9, imagen 2 de 2
    • Unplug wire connector and unscrew the Phillips 7mm screw with #1 Phillips screw driver.
  10. HP LaserJet P1102w Power Plug Replacement: paso 10, imagen 1 de 3 HP LaserJet P1102w Power Plug Replacement: paso 10, imagen 2 de 3 HP LaserJet P1102w Power Plug Replacement: paso 10, imagen 3 de 3
    • Apply pressure using spudger on top of the power plug to release it from metal housing. While doing that pull the power plug out.
Conclusión
3 personas más completaron esta guía.
Equipo
UW Stout, Team S6-G4, Ogden Fall 2018 Miembro de UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 36
Todo El Tiempo: 1,370
