Saltar al contenido principal
HP LaserJet P1102w Motherboard Replacement
Qué necesitas
  1. HP LaserJet P1102w Motherboard Replacement, Left Side Panel: paso 1, imagen 1 de 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: paso 1, imagen 2 de 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: paso 1, imagen 3 de 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Motherboard Replacement: paso 2, imagen 1 de 2 HP LaserJet P1102w Motherboard Replacement: paso 2, imagen 2 de 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Motherboard Replacement: paso 3, imagen 1 de 2 HP LaserJet P1102w Motherboard Replacement: paso 3, imagen 2 de 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Motherboard Replacement: paso 4, imagen 1 de 3 HP LaserJet P1102w Motherboard Replacement: paso 4, imagen 2 de 3 HP LaserJet P1102w Motherboard Replacement: paso 4, imagen 3 de 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Motherboard Replacement: paso 5, imagen 1 de 2 HP LaserJet P1102w Motherboard Replacement: paso 5, imagen 2 de 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Motherboard Replacement: paso 6, imagen 1 de 3 HP LaserJet P1102w Motherboard Replacement: paso 6, imagen 2 de 3 HP LaserJet P1102w Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Motherboard Replacement: paso 7, imagen 1 de 2 HP LaserJet P1102w Motherboard Replacement: paso 7, imagen 2 de 2
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Remove three #1 Phillips 6mm screws with the #1 Phillips screwdriver.
  9. HP LaserJet P1102w Motherboard Replacement: paso 9, imagen 1 de 3 HP LaserJet P1102w Motherboard Replacement: paso 9, imagen 2 de 3 HP LaserJet P1102w Motherboard Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using a pair of blunt nose tweezers, disconnect both ribbon wires.
    • With both ribbon wires removed we can lift the motherboard out of its housing.
    • There is a little black notch holding the motherboard down by the thumb in the final picture.
    • Be careful pulling, as ribbon wires are very fragile.
Conclusión
4 personas más completaron esta guía.
Jerome Etten
Miembro Desde 10/04/18
709 Reputación
4 Guías creadas
Equipo
UW Stout, Team S6-G4, Ogden Fall 2018 Miembro de UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 47
Todo El Tiempo: 1,869
