Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Pull on the two tabs on the back of the printer to release the left side cover. Remove the cover by rotating it towards the front of the printer. Remove the cover by rotating it towards the front of the printer.
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place. Lift the cover off of the printer. Lift the cover off of the printer.
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  4. Remove 4 screws on the back of the printer. Remove the back cover. Remove the back cover.
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  5. Remove 2 screws on the back of the printer, one on the left, and one on the front. The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover. The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  6. Disconnect the control panel cable and remove the top cover.
    • Disconnect the control panel cable and remove the top cover.
Conclusión
jdp23
Miembro Desde 22/08/13
1,275 Reputación
23 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 196
