Saltar al contenido principal
HP HDX 16-1160US Wifi Card Replacement
Qué necesitas
  1. HP HDX 16-1160US Wifi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US Wifi Card Replacement: paso 2, imagen 1 de 3 HP HDX 16-1160US Wifi Card Replacement: paso 2, imagen 2 de 3 HP HDX 16-1160US Wifi Card Replacement: paso 2, imagen 3 de 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US Wifi Card Replacement: paso 3, imagen 1 de 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: paso 4, imagen 1 de 2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: paso 4, imagen 2 de 2
    • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
    • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
    • Lift off the Wi-Fi card panel off using the opposite hand.
  5. HP HDX 16-1160US Wifi Card Replacement: paso 5, imagen 1 de 2 HP HDX 16-1160US Wifi Card Replacement: paso 5, imagen 2 de 2
    • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
  6. HP HDX 16-1160US Wifi Card Replacement: paso 6, imagen 1 de 1
    • Remove the two 4mm screws with the Phillips #1 screw driver.
  7. HP HDX 16-1160US Wifi Card Replacement: paso 7, imagen 1 de 1
    • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
    • Using the opposite hand, pull the Wi-Fi card to the left.
    • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
Conclusión
2 personas más completaron esta guía.
Marshall Reid
Miembro Desde 04/14/14
527 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-38, Maness Spring 2014 Miembro de Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 1,138
