Saltar al contenido principal
Partes
No se especificaron partes.
  1. Flip the device over so that the bottom side is facing up and use the Phillips #1 Screw Driver to remove the four 4mm screws on the cover panel. Lift the panel to remove it from the device.
    • Flip the device over so that the bottom side is facing up and use the Phillips #1 Screw Driver to remove the four 4mm screws on the cover panel.
    • Lift the panel to remove it from the device.
  2. Remove the RAM by placing your thumbs on the silver tabs on each side of the RAM stick and pulling the tabs away from the RAM stick. The RAM stick should "flip" up when it is released from its holders. Pull the RAM stick toward you to remove it.
    • Remove the RAM by placing your thumbs on the silver tabs on each side of the RAM stick and pulling the tabs away from the RAM stick.
    • The RAM stick should "flip" up when it is released from its holders.
    • Pull the RAM stick toward you to remove it.
    • Repeat the above step to remove the second RAM stick
Conclusión
2 personas más completaron esta guía.
Marshall Reid
Miembro Desde 14/04/14
473 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-38, Maness Spring 2014 Miembro de Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 418
