Saltar al contenido principal
HP HDX 16-1160US DVD Drive Replacement
Qué necesitas
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: paso 2, imagen 1 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 2, imagen 2 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 2, imagen 3 de 3
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: paso 3, imagen 1 de 1
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: paso 5, imagen 1 de 1
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: paso 6, imagen 1 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 6, imagen 2 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 6, imagen 3 de 3
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: paso 7, imagen 1 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 7, imagen 2 de 3 HP HDX 16-1160US DVD Drive Replacement: paso 7, imagen 3 de 3
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: paso 8, imagen 1 de 2 HP HDX 16-1160US DVD Drive Replacement: paso 8, imagen 2 de 2
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: paso 9, imagen 1 de 2 HP HDX 16-1160US DVD Drive Replacement: paso 9, imagen 2 de 2
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: paso 10, imagen 1 de 1
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: paso 11, imagen 1 de 1
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: paso 12, imagen 1 de 1
    • Push down and pull out the DVD on the left side of the device.
Conclusión
3 personas más completaron esta guía.
Marshall Reid
Miembro Desde 04/14/14
527 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-38, Maness Spring 2014 Miembro de Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,451
